So that $7,500 came from nowhere? Actually, the numbers are only compelling when you factor in the taxpayer-subsidized rebates, tax credits and the like. For example, you stated a 10½¢ per kWh rate reduction and a tax credit of $7,500.00. Those are not insignificant numbers and they have to be factored into any equation for a fair comparison. Take away those taxpayer-supplied gifts and it's a vastly different comparison. There have been enough analyses done to show that, without the taxpayer-supplied gifts, EV ownership is slightly more expensive than a gasoline-powered car. IMO. there are enough manipulations of the numbers that it is something I want to debate. But I appreciate the warning and suggest that your using manipulated numbers in order to prove your case may explain why you're not able to have a rational discussion regarding EV cars. You should also know that I am neither a proponent or opponent of EV cars, I only look for truth and common sense. And there has been far too much exaggeration, manipulation, speculation and stretching of the truth for me to take EV cars seriously. It's been said that, in order to replace an existing product, the new product has to be 10X better than the existing product. I don't see EVs being even equally as good as the existing product on a level playing field.
