Lightest front runner?
In this case the tire is heavier than the wheel so more tire and less wheel probably wouldn’t be lighter. I do not like the larger sidewall on frontrunners.
I was wondering that
Thread Starter #22
My wheels are 18" fronts.....Racestar Darkstar and are light for what they cost....MT doesn't have an 18 that I see Hoosier may be the one....its about 10lbs lighter than my current m&h.
AlleyCat
Oro Valley
16 HC Challenger
The Mickey Thompson sportsman radial, heavy at 25 pounds, is only rated to 130 mph. The other lighter radial they make has too low of a load. The thing about the super light hoosier is they do not give specs. There can't be a lot of strength in them at 12 pounds a piece. I have used them. But I wonder.
I use the ET street it’s whatever have been to 142 on them
??? I saw a Viper run 260 mph on Sportsman radial. I was on that tire at 183 in the half at 4500 lbs. I’m currently running the MT front that’s half the weight of the Sportsman and near 170 in the 1/4 last time out. Plans are to run 200 on that tire. Stop worrying
AlleyCat
Oro Valley
16 HC Challenger
Just was saying what mt said on their website. You are a brave one Marc. And you ain't no youngster. :)
I think he’s talking about the et street fronts, which is what I have. Weight rating is a lot less than the sportsmans, but I’ve ran them without issue
AlleyCat
Oro Valley
16 HC Challenger
I do like those as they are radials. Radials have less rolling resistance. I do not know the formula even if there is one comparing a lighter bias with more rolling resistance compared to a heavier radial.
Demon Dan
San Pedro
2018 Demon
The lightest:
Hoosier Drag Race Front.
28x4.5-18; PN 18112.
AlleyCat
Oro Valley
16 HC Challenger
On the 2018 demon what tire up front did the crate skinny come with?
The ET street fronts look like a good tire but if I recall they are heavier now then when they 1st came out? Need to weigh Jons against my M&H fronts on the same scale. They are are both mounted on the same forgestar wheels
AlleyCat
Oro Valley
16 HC Challenger
They are 17.6 pounds a piece. Not sure if they were lighter before.
There was a thread where some where saying they were heavier then that now. Remember reading it and was thinking it made no sense
Mine weigh like 14 lbs if that. My front runners weigh 32” each with tire. I bought them 2 years ago
32 pounds. Don’t go based off what a website says for delivery weight, that’s not always true. I have 18” forgestar f14 front runners
Someone got a rear seat delete and online it said delivery weight was over 70 pounds lol
Can probably search on here for my thread where I weighed my drag setup vs my stock setup
AlleyCat
Oro Valley
16 HC Challenger
I think the demon with the crate front runners used a Mickey Thompson bias ply tire.
Started looking and seeing crates with wheels only. You may have had to buy tires?
