For sale BMR coolant tank.
Trader history for fumanchu182 (2)
Comes pre-wrapped in heat shield and includes additional vacuum fill lid. I did the engineering and solved a problem for them and now you can fill your coolant system under vacuum. Fully functional and a great addition for the summer racer running a water setup.
$425.00 shipped.
Yo Foo Moo Hickstah Here Coolant Tank,
Perty slick tank yo gots there. A couple of questions fer ya.As a past employee of Tennessee Tank & Steel and Insulators Inc, Chattanooga, Tn. Holding companies of the Perry Smith conglomerations. How much fluid does it hold, % of inhibited Glychol to mixing fluid does it take, thickness of FSK finishing insulation is there, has your engineering thought process come accross the subject of placing a coil inside the tank? That way fill the coil full of anti freeze or the like, and fill the tank with circulationg cold water?? Just a thought. What material is the tank made from? Stainless, copper, aluminized zinc compound? Reason fer assking is, wood like to know if a de- electric fitting would be necessary to fitt a different metal to it? Dyelectric union. Good job. Oh,,, are the piping lines, supply and return and pump, need insulation to prevent condensation? Youz could shoot me a message on the inbox to discuss these.
Thanx
