New Red Brembo Pads Destroyed my brake system ** PHOTOS
X
Istanbul
Turkey
Hellcat Widebody
Thread Starter #81
I dont have the bolt pictures guys :(
By the way thank you guys for helping with the informations because this could happen to any of us here. Better to be prepared in order to prevent this to happen in the future
X
Istanbul
Turkey
Hellcat Widebody
Thread Starter #82
Guys is there a chance about there was an air in the system?
Calipers removed to paint them.
Brake fluid renewed.
Discs removed and machined
New red brembos installed.
In this process if there was a little air left in the system this could happen? But keep in mind rear discs are ok they have the old original brembo brake pads.
Only front pads were changed
Those calipers were definitely biting on those rotors
The drag should have been very noticeable
Hey Dave are the brakes sticking
Dave s not here man
#84
New fact! Calipers were removed for painting. Did not know that until the morning. What do think now Doctor @BULL ?
This is good OP. You can at least increase the size and number of the Defendants now. Those pads are looking more and more harmless with each post. Now you can forget about adding Brembo to that list however. So far my services are about up to one hour for ya. Now I am somewhere between the painter and the installer. Where are the bolts? Fell out??
I did read you drive this car for 45k miles before this 100 mile issue?
Air isn't the problem, that's for sure.
I do want to verify those pad p/n's, but right now I can't.
Paint caused the pistons to stick? Maybe, but that would have been apparent immediately as well (as a lack of fine modulation).
Unless there is more, I'm still of the opinion that the root cause for this is the installation by the shop, with the mounting bolts being the major contributing factor.
I'm positive that there were signs, but who knows at this point.
Focus on a thorough, proper repair and lesson learned.
As for the pads, go with the Z26s this time, they are well known and proven by many.
@BULL - The p/n checks out, one of the first things I did.
The caliper rebuild… why did it take 5 pages for that to come to light?!?
McLovin
Syracuse
2015 Challenger Hellcat
#87
Regardless of the cause, there is no way those rotors got to that point over 100 miles without something obviously noticeable (sound...smell...feel).
And since that isn't being admitted, I'm taking this entire thread with a huge grain of salt.
Grains of salt...are generally uniform is size....I suspect what you elude to....is a bag of salt...(if needed..I wholesale it in 50/80lb bags);)
How much? Do you have pretzel salt as well?
Yup...pretzel salt is more than fine salt...it comes in clear...(opaque) and white...roughly.20 cents a lb. in bulk...
And we even have rock salt for winter road and sidewalks
McLovin
Syracuse
#92
Next time I tell someone to go pound salt, I'll know where to send them
Ronin
Muspelheim
'22 Challenger Hellcat
#93
…that’s my sticking point with this whole 💩 show…this all happened in 100 miles AND there was no audible, tactile, odor…NO indication whatsoever that this massive failure was underway…
Sounds like a combination of installation error combined with a complete lack of situational awareness…
Then again, it could just be a troll 🧌 thread and we’re all in…🤣
2fast4u
Edwardsburg
#94
I too am wondering about the caliper removal. I actually did not see he had "rebuilt" the calipers, thought it was just paint...that being said, if o rings were not put on/ seated correctly then it would make more sense as to root cause. Caliper would not move smoothly and Voila...above problems explained.
MJS73
Moparland
2020 Challenger Hellcat
#95
Are you sure? Those look like air gouges and air with too much oxygem can be highly corrosive.
I'm expecting a post from Powerstop any minute..."No, please don't"
But no two are alike.
Same thing is said about snowflakes. To which I say, “Prove it.” ;)
Hatermkr
West bend
2016 helldemon
#97
Nice info you are giving guys. Keep in mind i did highway drive with 150mph sometimes to test.
I made passes on mine at the track 165 mpg to zero mine don’t look at this
Hatermkr
West bend
2016 helldemon
#98
I do have a full sent of front rotors caliper is pads with hoses I can sell you
No...NO NO NO...don't get those Science guys all lathered up...:censored::censored::censored::censored:
We could just talk about salt again. Damn shit is not far off given the weather in most of the north state this weekend. I am afraid the queen is parked for the year. My brakes are being put away looking good.
Let’s see. I suppose driving along with the cruise control on, after stopping fairly aggressively the system on all four pads goes retarded and applies pressure. Okay, then lots of crap happens. Shit is hot, very hot maybe.
Smell anything yet?
Bolts become loose? Now you have drag on the steering due to differential pressures of the pad/rotor. Both sides he says. What kind of a road do you have to not feel this yet? Steering don’t feel strange? Never used the brakes in 100 miles? If you did WTF did it feel like? Okay.
Those calipers loose at least one bolt. Causes them to fall off laterally. Fuck, hits the wheel. So bad it has grinded the wheel. Twisted it nearly.
WTF, can’t feel that?
Who has the bolts? Where are the calipers so someone who knows their shit can tell you WTF is going on with them before you throw them away.
