A little help for a non SRT brother??
MaxWedge355X
911 Dispatcher
Waukesha
2018 Durango Citadel AP
Hey guys,
I have a 2018 Durango Citadel AP. Trying to swap in a SRT cluster using AlfaOBD. When I go into the body computer and switch 'Vehicle is SRT' to yes, it triggers all sorts of warnings on the dashboard. ABS,SRS, FCW, ESC..... Can't clear the codes at all, other than to turn 'Vehicle is SRT' to No, then everything clears, but I also lose the tach, tire pressure readings, as well as all the other fun stuff in the EVIC. I hoping someone here with an '18 SRT Durango would be kind enough to share a BCM status log with me so I can compare it to mine and find the differences. It would be much appreciated.
Welcome and good luck with your mod.
M
MaxWedge355X
911 Dispatcher
Waukesha
Thank you
