- Mesa
- AZ
- 2017 Dodge Challenger Hellcat
With all the performance mods finally done, I am going to 'fix' the factory sound system.
I won't trash the H/K system. There has really never been a factory sound system from any manufacturer that was very good. I didn't special order it. It came with the car and had zero influence on my purchase decision.
Fixing it means throwing away everything but the head unit. Nothing worse than a cobbled up dash, so I need to make that work as well as possible.
Some of the items I am using are off the shelve pieces. Readily available. Some are less available and take real effort to get, with long lead shipping times.
Fixing head unit is easy. Crutchfield sells all 3 pieces needed.
AmpPRO modules; AP4-CH41 (R.2) , APH-CH03 Dodge Speaker connection harness, APA-TOS1 TOSLINK digital output for the AP4-CH41.
Subwoofer is a JL Audio 13TW5v2-2. 13.5" diameter. This sub is a very shallow mount (2.6") and requires a custom box with .8 cu ft, sealed. A local custom shop will build the box out of fiberglass and cover to match the trunk.
It should fit and look very similar to a JL Audio Stealth-box and put out plenty of low frequency joy. If not, I can always add a second one in the other trunk corner.
Speakers.
For the cabin, I will be using 2 pair of Focal PS 165 F3 full range 3 way component speakers. I will not be using the included passive crossovers. So 12 speakers total with an active crossover setup.
DSP.
The list of available 12 channel DSP's for car audio is very short. Initially, I was going to use a combination DSP- 75W/ch Amplifier in 12 channels. But the package size was pretty small and I was concerned about the thermals.
I live in a pretty hot climate, so I will separate that all in one piece into 3 pieces. The DSP is a Helix DSP Ultra 12 channel. These can be difficult to get. Helix is a pretty high end line and its all made in Germany. The number of
US importers is very small, and they do not carry the entire line. I did find one.
Amplifiers
I wanted the amps to match the DSP. So for the subwoofer I'm using a Helix M One X Mono-block, 700W @ 2 ohms.
For the 12 cabin component speakers I am using a pair of Helix M 6 channel amps, 100W/ch in either 2 or 4 ohms.
These 6 channel amps are specifically made for active crossover setups using a 3 way component speaker setup.
There are 3 different pairs of inputs. One for mid bass, with a low pass filter. One for mid-range with both a low and hi pass filter. And one for tweeters with just a high pass filter.
Its going to easily be several weeks before I have all the pieces in hand. Will check back periodically with pics and updates.
Speakers.
DSP.
Amplifiers
