KNG Wraps Wicker & Diffuser Installed (with pics)
Apopka
2020 Charger Scat Pack
Hello all! Finally got both the products in that I have been looking forward to for a while now and wanted to share with everyone! Even though I have a Scat Pack, both of these will also work for Hellcat Chargers.
Up until this point I had been looking for a rear diffuser for my 2020 Charger Scat Pack and kept striking out for one reason or another. The ZL1 AddOn's unit mounted well but I dont like the look of it, Downforce Solutions doesn't make one (yet according to him) for the Charger, the lower valance clip on unit isnt the right look for me and I would also like it to be remove-able, other vendors have gone out of business, etc etc. Finally I found the KNG Wraps diffuser and decided to pull the trigger on it. The one that I got is the " Scatpack - Hellcat V2 Diffuser" with the rounded edges option. It comes with some hardware that is supposed to replace 4x factory screws under the rear bumper. After using the supplied screws I personally wanted a bit more assurance so instead replaced the screws with 1/4-20 rivnuts and some stainless steel bolts and loctite to top it off.
Secondly I also got a Wicker Bill with glass in the "nascar" variant. This finish has a smoked lexan center that follows the curves of the wicker itself as opposed to being a square center that sticks out from the rest of the wicker curvature. Asked for upgraded hardware and this arrived with 1/4-20 rivnuts, black headed bolts and black washers. Installation was super simple, just have to make sure you measure 10x times before you drill the first hole! The smoked center is very visible in the second picture below, the little white triangle is my neighbors roof, I didn't leave some of the shipping cover on :cool: )
Both products are clearly handmade and got some attention before they shipped. The diffuser is very light for its size as its made out of a aluminum/lexan composite it seems. The fins are cut to follow the (different) curvatures throughout the bumper which makes final install look very sleek. The wicker looks great on the car and is just the right size. It will look a little bit bigger in the pictures than it does in real life but you for sure wont miss it looking at the car. Overall very happy with the products and service from KNG Wraps and if anyone is in the market for either of these products you should review these!
Now on to some pics!!
Looks killer.
Car looks great!
SergL
Apopka
Looks killer.
Car looks great!
Thank you sir! Used to have a challenger and never found anything that I liked for it, leave it up to me getting a charger that I finally did! :) All good, now its on to rims and tires!
What type of wheels you looking for?
SergL
Apopka
A little bit of money, but you ever look at Triumph?
one look at Triumph wheels is all it takes...(y)
tkracing1
Bay Area
2017 challenger
Nicely done... looks good!
SergL
Apopka
Have heard of them before, looking now. Do like the 5 spoke look that I also had on my hellcat challenger, before I deep dive into their site you happen to know of one that would be similar?
EDIT: found a few that are close-ish. thanks for the tip!
Thank you! Very happy with it indeed!
Actually looks more like a bee now. The transparent wing does it, I think,
Phizzle
San Francisco
2018 Dodge Charger Hellcat
Nice and agressive looking! I follow KNG Wraps on IG, their products stand out to me more than ZL1 addons. Might have to splurge on a set of rear aprons from them one of these days.
SergL
Apopka
Right out of the box the diffuser for ZL1 has a better mounting system but as a product itself I think it lacks "the look". The other side is that on the backside of the charger, under the bumper its very hard to get any real chassis mounted points. So with that in mind and the various finish options on the fins that KNG offered it was a no brainer for me. I will probably end up going back and adding some more mounting points but as a product itself the KNG diffuser cant be beat I feel.
I have the SVS Triumph.
Black with red nuts and logo.
SergL
Apopka
SergL
Apopka
That's my 16 before it was totaled.
Same wheels on my 19, but 11.5 on the rear.
Very nice! Def will keep these guys in mind when times comes. They clearly have a much larger color selection which might close the deal.
Dang. Forgot how much I miss that car
I get it! Went from my challenger hellcat to the charger scat pack so rest assured I can relate one way or the other! :cool:
