New Vibration, What Could it Be?
Bordercat_797
Bordercat_797
Active Duty U.S. Army
El Paso
2020 Dodge CHALLENGER HELLCAT REDEYE WIDEBODY
Thread Starter #21
Finally, got the driveshaft off the car, and sure enough, the rubber on around the center carrier bearing was shot. So now the question is, should I go with the more economical fix with the JXB replacement, or go to a one-piece DS from DSS. Considering the power I am making, I am more inclined to upgrade the DS, but I would love to hear everyone's opinions or past experiences with going this route.
Depends on if you go to the track. Street car only the stock one will be fine. I know my vibration isn't the ds
I've blown one of these up too, stick with the one piece :cool:
I know this might be a long shot, do you have a drive shaft hoop? is it contacting the well/hump for the drive shaft?
Pulled loop off yesterday and still appears to be there
Your wife's friend.
@jonx96 let me borrow is redeye axles (thanks Jon) and we changed those out today. Appears the vibration is gone. Guess I will be buying some new axles
Where you running after market axles?
I have gforce renegades axles. They were bought used with low miles back in 2021. I installed them along with the 3.09s and aluminum driveshaft. I had some bad wheel hop last year on a couple of passes and could have damaged them then before installing the aad arms and 315 tires. Seemed to be ok last year though. I put a new driveshaft in and had 3 people in the car when I really noticed it so thought it was the ds so pulled it back out and put the other back in.
I have dss renegades axles. They were bought used with low miles back in 2021. I installed them along with the 3.09s and aluminum driveshaft. I had some bad wheel hop last year on a couple of passes and could have damaged them then before installing the aad arms and 315 tires. Seemed to be ok last year though. I put a new driveshaft in and had 3 people in the car when I really noticed it so thought it was the ds so pulled it back out and put the other back in.
They are not Dss. Yours are gforce
Glad you found it. I have a hate/hate relationship for gforce. Fugg em. 😂
I was down to axles or rear end but either was going to be work to see which it was
Chex you's ladies purse??
Holy cow... visual or technical inspection of old axles?
