- Riverside
- CA
- 2015 Dodge Charger Hellcat!
First... like the cellcomm blocker, I'm not selling this item. It is an easy diy project. Conversely you can buy the right connector, with a bnc pigtail and a bnc 50 ohm terminator and accomplish the same thing (for about $40).
So, I cancelled my Sirius account, years ago. They recently sent me a letter to tell me they have activated service, on my radio, for three months. Well, I don't want their crappy service, and I don't want them collecting and selling my data.
I broke open the service manual and figured out a way to block satcomms. You may remember, I made a cell blocker, not too long ago. This is the same principal, as that piece of hardware.
Now, Stellantis and Sirius are blocked, from any "updates", or data collection in regards to my vehicle. If you are concerned about your privacy and don't have a Sirius account, the process to make a blocker is the same as my cell block:
https://www.hellcatforum.org/threads/how-to-cell-comm-killer.12474/
Even if you don't have an account, you can bet your ass they're tracking you and collecting data. They have full access, to the car's network.
For a satcomm blocker, you will need the following:
FAKRA K (CURRY) connector for RG58.
One 50 ohm wirewound 1%, 3 watt resistor. This is critical, as the tolerance for the network to throw a code is very tight.
You can forego the faraday material, but be sure to epoxy the resistor, after you solder it to the conductor, and install heat shrink over the resistor, after the epoxy is dry.
Pull the screen.
Remove the curry colored connector and replace it, with the satcomm blocker. Replace the screen and put your dash back together.
Sat blocked. No codes. No warning messages. No data collection. No snooping.
Pull the screen.
- 7
- 3
- 1
- Show All
