- West Texas
- TX
- 2017 Charger HC (once upon a time)
One owner – 53,607 miles
6.0 Liter LS2 mated to A4 transmission
MP112 Magnuson supercharger with intercooler
Upgraded injectors
Kenne Bell Boost-a-pump
Kooks ceramic coated long tube headers
High-flow racing catalytic converters
Resonator delete; replaced with X-pipe
Mufflers replaced with racing bullets
Subframe connectors / jacking rails
PCM and Trans tuned by Chuck Anders at House of Power in Houston
Dyno sheets show 450 hp / 450 ft lbs of torque at the wheels (550/550 at the crank)
Two ignition keys and one glove compartment key (rubber on one key wearing through)
Two Aeroforce scan gauges mounted in internet dash binnacle (better binnacles out there if desired). Currently set to show IAT, Boost/vacuum, coolant temp, and voltage. Original binnacle mount cover plate included in sale.
Hard wired Beltronic RX65 radar detector included in sale
Dashhawk instrumentation and trouble code reader and mount included in sale
Set of 4 staggered Beyern chrome wheels
245 40 ZR 18 Ventus V12 Evo tires up front
275 35 ZR 18 Michelin Pilot Sport tires on the rear
JHP Australian trunk lid mounted wing (original surf board wing included in sale)
Rear valence painted flat black
Two OEM wheels with BFGoodrich drag radials included in sale
Passenger’s door locking mechanism binds intermittently. Must lock and unlock the door by hand from inside the car. Complete locking assembly included in sale (have not bothered to install it)
Normal scratches and wear and tear
- 3
