I'm not a fan of pump 93 for any repeated racing in a forced induction setup like hellcats and redeyes. It's like playing Russian roulette with your engine.
At best, you will most likely have some knock retard, which slows the car down. At worst, you buy some bad pump 93 and something far worse happens. I don't trust it and don't like using it to race. Won't use boostane either. Look at what it does to spark plugs, o2 sensors, converters, etc.
If you choose not to use e85 ( which is also the only pump fuel you can test)then I would use Sunoco 260gt or 260gt plus as safe alternatives for racing purposes. Keep in mind that any gasoline based stock boost setup (and in some cases pullied setups also) will get gapped by the same stock boost setup on e85 at the track.
