Who else here is doing the Litens Hellraiser 3.17"
Mo-par!
Mt. Gretna
2018 Demon #1282
Claims of 70HP gains with no tune on VP MS109 race fuel. I'm scheduled for an install at HHP in October.
Popcorn is ready!
70HP sounds...
Optimistic???
Do you have a baseline dyno to compare against?
And how much of that is the fuel?
RedEye19FL
Bradenton
2019 TorRed Challenger RedEye
OOPS! I didn't see this thread and posted the 3.17 in another thread. I'll delete mine. No need to repeat.
RedEye19FL
Bradenton
No PCM unlock = warranty intact? What do you think?
SunnyS
Siesta Key
2019 Hellcat
I am sure a sharp eyed mechanic will see that the stock pulley is not on the supercharger anymore.
It would be very hard to tell the difference since it's 3/10th of an inch.
But 70HP?? That's at the crank I assume?
motorhead
Ottawa
2019 Challenger HC Widebody
I guess if you want a little bit more, why not?
Hell - I am still pretty convinced you could pulley down and add a supplemental fuel system, and just keep going on making power on the stock tune as long as the IDC doesn't shut you down. This has worked on speed density systems for ages.
steven_sbs
Southern
Plum Crazy 2019 Redeye Widebody
Quote from the Allpar story:
While all of the testing on every model hasn’t been completed, there has been extensive testing done on a Demon with impressive results. When running on 93 octane pump gas, a 2018 Challenger Demon with this Litens 3.17 pulley picked up around 45 wheel horsepower and when that same Demon was running on MS109 race gas, it gained 70 rear wheel horsepower. On a standard Hellcat, the testing has shown gains upwards of 25 rear wheel horsepower on 93 octane pump gas, and those numbers should be relatively similar for the Challenger and Charger, while the all-wheel-drive Jeep Trackhawk may see slightly lower gains since it is spinning all four wheels. As for the Redeye, we don’t have official numbers just yet, but they should be similar to the Demon on pump gas, perhaps slightly lower.
In other words, if you drive a Hellcat Challenger, Hellcat Charger or Jeep Trackhawk, the Litens 3.17 Hellraiser pulley can add around 25 wheel horsepower without a tune or the cost of an unlocked PCM. In a Challenger Redeye or Demon, expect closer to 45 rear wheel horsepower on pump gas and Demon owners can pick up 70 at the wheels when running on race gas – again, all of this without an aftermarket tune.
Probably a real good option for RE and Demon with them having the bigger blower.
Mo-par!
Mo-par!
Mt. Gretna
2018 Demon #1282
Yeah - that is why I have it scheduled...
Hemiride
Farwell
Let us know your thoughts after
Rcasa20
Indian Shores
2019 Redeye Widebody (sold)
I dropped my car off at Zen Racing in the ATL on Friday for a Dusterhoff tune and a variety of mods including the 3.17. Unfortunately, I won’t know how much of my gains is due directly to the 3.17.
SunnyS
Siesta Key
2019 Hellcat
All the excitement is you put this pulley on without having to do a tune. Tell us why you did not go for a smaller pulley since you are getting a tune.
Rcasa20
Indian Shores
I’ve got a Redeye and want to stay on 93. Curt recommended 3.17 as the smallest so I’m trusting him.
SunnyS
Siesta Key
2019 Hellcat
You are in good hands . I am thinking of the same pulley . Let us know how it works out.
Mo-par!
Mo-par!
Mt. Gretna
2018 Demon #1282
Correct - on an RE or Demon, a 2.85 or smaller kills using pump 93 on the street...
I agree, although there's a guy on here that reports he has a 2.85 on his RE with 93 tuned by Pietz.
Mo-par!
Mo-par!
Mt. Gretna
2018 Demon #1282
I hear it can be done by bleeding off boost? Who's got the info?
