Thread Starter #1,081
Here we go
I went with the Tapp stage 1.5 that has the 295 pumps. Nice upgrade
Gotta give it to Whipple, that thing looks amazing.
Thread Starter #1,084
Fuel pumps changed, I took a bunch of pictures to make a step by step on how to do it, not hard, done in less than an hour.
801F5F29-51F7-4AEE-B85B-F8F7282B84AB.jpeg E53A7B31-E11B-407F-BC49-A4F33FC5FFF6.jpeg 09C94533-2BF9-4E4A-A530-29C505FBFC1A.jpeg C6CB5A3C-2F5A-4F71-A6B9-C862D4C589FE.jpeg 2BE0372C-D217-46A3-A8E8-3A1333CD7426.jpeg D5D08A4B-096D-4C3F-9F41-AA6ADBA63D62.jpeg F4E9524D-3DBF-499A-973C-303CFEFFA9F0.jpeg 6ADB7E09-DD10-4B81-94AC-3745874FF46D.jpeg 30227D56-B9C5-4B99-A08D-0DB20BBCC5EE.jpeg 92C92C6A-D918-4F99-8787-7F51A12D5E90.jpeg 33004E0A-CB28-4FC0-BB32-AF1AFAABF29E.jpeg 4113C9B3-357B-4951-8005-C86FD5A0B82C.jpeg
Thread Starter #1,085
Unfortunately the longest belt I have on hand is about 3/4 of an inch too short :-( if I wouldn’t have used the insulator spacers it probably would’ve fit. I was looking to see if I could find one at any auto parts store but I highly doubt it unfortunately. And I’m getting called into work to double unfortunately lol but at least some of the auto parts stores I would hunt down are on that way lol so I’m not too pissed off about it is what it is that’s what helps pay for the toys even though unfortunately I’ll be a negative triple overtime today lol
Thread Starter #1,086
I have to do something with these coolant hoses upfront, I hate the way they look atm, I’ll probably put some AN 90s on them and neaten up the ends
Thread Starter #1,087
Well I couldn’t find the right size belt so I found a seven rib belt that worked that let me start it up and take it out. Got to block from the house throttlebody error :( reset it relearn the throttlebody, throttlebody error again came home change some wiring around that I didn’t like from the Whipple harness, direct wired to sensors direct not through the Whipple pigtails that didn’t like not knowing where the wires were going or not again same thing. Came home change the throttlebody to the BBK went out same thing throttle body error, came home texted my buddy @jonx96 I don’t know what it was doing but he sent me a tune revision without even looking at a log in about 10 minutes and no more throttlebody error :). Tge tune probably still need some brushed up I didn’t give it too much of a hit beyond a bit in third, I saw 28 pounds of boost which is going to be way too much so review these stones and go from here but at least we’ve got some initial stuff to start working with. Hats off 🎩 to @jonx96, If that was a big name tuner I would be waiting a week or more. I recommend his tuning services to anyone versus going with one of the big guys. 👍👍 THANK YOU JON!!
That whipple pallet thread he said his made 18 lbs on the 3.75. I thought that was high but I guess you found it to be true by what you made on the 3.00. You made a comment. I guess based on what he said I would have started with the 3.75
So how did 28lbs feel?
Thread Starter #1,090
Was going to but could not find a belt that would match it so I used the 3.00. I can’t believe 28 psi though on a stock lower??
Thread Starter #1,091
I don’t know yet if it really made 28 psi, PR (pressure ratio) was tops 2.22, I’ve seen 2.55 on my other blower. But the Whipple had the bypass partially open, its tune needs some tweaking I think. To early to tell yet, drive maybe 4 miles, actually only to the grocery store and back believe it or not lol.
Thread Starter #1,092
I put the 105 back on, going for fuel and a driving log, nothing crazy, need the pro Jon to look it over yet :)
Going to order a few belts tomorrow.
What happened to making 18psi 😂
You’ll prolly need another table adjusted for that much boost.
Thread Starter #1,094
OK, here’s the results, first 3-4 hit tonight, gained about 1/2 second in the 60-130 running from prior runs last 2-3 weeks. My PB in about 0 DA 45F air was around a 5.78
C96E8388-071B-457A-9A9D-0B0D5C0DE97E.png 3556F90F-4060-4BFF-9A38-0450338B83E6.png
But this is it for the fuel system and injectors even with upgrading the pumps to the 295’s, it’s done pump and injector wise.
6ABDE4F6-3B1F-49DC-9204-9669D68F9930.jpeg 127C2626-DBC7-4180-B065-B52065DB6E82.jpeg F028753F-A189-4F83-ABE2-FEF318CA581C.jpeg
Perfect pick of pulley size, 3.00, netting a solid 22 psi accross the rpm band with a peak of 22.6 psi, PR in the 2.65 range. No doubt she’s over 1000 wheel now, dyno shop guy is on vacation, will hit him up in the near future. I see 10 second street 1/4’s on the horizon :)
Nice initial improvement! So, 3-pumps (285?, 295?) and which injectors are next?
Thread Starter #1,096
No, just dual 295’s, may hang a third 285 (because it has a check valve) on a boost controlled switch that comes on only during high boost. Present Injectors are ID1300’s.
View attachment 80740 View attachment 80741
View attachment 80742 View attachment 80743 View attachment 80744
I thought you said the 3.0 pulley made 28 lbs?
@drag racer was asking are you going to 3 pumps and what injectors are next
Thread Starter #1,099
But remember I said I’d have to review that? That was at a quick glance at the laptop screen and was 28 psi of manifold pressure, minus 14 for atmosphere it was only 14 really. 22.5-23 is the real number after reviewing last nights log with a belt that wasn’t slipping
Before, the blue line is boost, see it fall off
Last night, see boost hold steady?
See the 37 lbs of manifold absolute pressure? Subtract 14.2 baro and boost is about 22.8 psi, MAP shows it at 22.6.
The guy posting pressure numbers with the pulley sizes listed being driven by a stock size lower must be mistaken in what he’s interpreting as boost numbers, he may be looking at manifold pressure and not subtracting baro if I had to guess.
I'm surprised you have not upgraded those heavy steel idlers pulleys that down spin very well:unsure:
I bought all 3 from TBA
