Two Tuned Redeyes
Trader history for Jon-MooredPerformanceLLC (2)
Tuckerracing
Whitehouse
new welds and the tires come in this week, how have the 275's hooked I want to try small tire classes?
you can get them to hook, just be easy on the launch or have it turned down on the hit.
#82
Nope. Chargers too. Same suspension.
Follow-up on the Racestar 95 17x10.5’s: My friend with the Chargers had 9.5’s on his HCNB and they did not require short sway bar end links. He had Racestar 92 17x11’s on his ’22 RE and no need for short links. He contacted me today, he tried to put his new Racestar 95 17x10.5’s on and they hit the sway bar just like mine, so it appears that David was spot on. Thanks David!
Not a big deal.
The Challengers and Chargers have the same suspension. I'm not sure what the big deal is getting shorter links? Makes everything easier and cost $100
@Speedy - are your washers flat or are they dimpled? Wondering if your washers are just a little smaller than what everyone else got, because that would solve the problem. The washers that come with most of them are exactly the diameter of the hole they need to go into, and once their squished or dust builds up in the barrels, the tolerance disappears and it’s an interference fit. No socket will solve the problem related to the washer.
Flat I guess, they look like washers. I can take a measure of the diameter of one if someone wants to compare them.
Yeah, if they’re flat and not scraping the barrels, you have smaller washers (or bigger barrels). Just look at them the next time they’re in your hands… mine were far from flat.
