Sign Up! To view all forums and unlock additional cool features
I guess I’m curious as to how quick these cars can go with stock motor and blower without adding nitrous basic pulley set ups and either race gas or ethanol
The fastest 2.4 (stock HC) blower only is the UnicornPiss Challenger run by Sumit. He just went 8.99. The fastest aftermarket blower only is the 4.5 Whipple Charger run by Zhc who just went 8.81. Those are street cars. Of coarse the Epling car can go faster on blower only but that’s another thing.
The stock HP90 A8 trans is pretty stout. I raced my old setup for nearly 3 years, made 50+ passes on a 2.50 upper + lower pulley combo, hundreds more on less aggressive combos, and it continued to perform well.
All is needed is the right amount of caressing and they can usually last a while.
Hell for a price of a plane ticket, I'll fly you in. We have peanuts for you compared to that. But it will still be less expensive for me. Just suspension parts front and back including dropping the cradle for bushings. I'll even feed and house you.
Here’s stock clutch pack clearances
I checked the e clutch in mine right now and it measures 110in as you can see the after run in should be a maximum of 89 makes you wonder how close ZF ACTUALLY CHECKS THEM BECAUSE TGERE ISNT ANY CLUTCH MATERIAL MISSING IN MINE TEY WERE JUST GLAZED OVER 🤔
I checked the e clutch in mine right now and it measures 110in as you can see the after run in should be a maximum of 89 makes you wonder how close ZF ACTUALLY CHECKS THEM BECAUSE TGERE ISNT ANY CLUTCH MATERIAL MISSING IN MINE TEY WERE JUST GLAZED OVER 🤔 View attachment 7923
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
