- Ottawa
- Non-US
- Canada
- 2019 Challenger HC Widebody
Pretty sure those HC ZF8 transmissions are built in Mexico https://www.zf.com/mobile/en/compan...de/north_america/mexico_locations/mexico.html). Germans can engineer things all they want, but if you don't follow the specs this is what you get. I'd be willing to be that other high-end (and not just over priced) luxury cars that get the ZF 8s are more tightly built.
EDIT - NM, looks like they are assembled in the US:
Chrysler Group LLC initially received the 8HP 8-speed automatic transmissions from the ZF plant in Saarbrucken, Germany. By 2013, in parallel with Chrysler Group, ZF had set up a new transmission production plant in Gray Court, South Carolina.[7] ZF Friedrichshafen and Chrysler Group have reached a supply and license agreement for the 8HP. Chrysler Group is licensed to produce the 8HP at the company’s Kokomo Transmission Plant and the Kokomo Casting plant, production began in 2013. This transmission is marketed by Chrysler under their own brand name, the Torqueflite 8.[9]
2nd generation 8HP products were released starting in 2014. Efficiency improvements over the original design include a wider ratio spread of 7.8:1, reduced drag torque from the shift elements, reduction in required oil pump pressure, and broadened use of the coasting and start-stop systems.[10] ZF estimated fuel economy improvement over 1st generation 8HP kits to be 3%. Refinements were also made with respect to vibration.
3rd generation 8HP products were released starting in 2018. Major improvements are total spread of 8.6 and a fuel economy improvement of 2.5% compared to the 2nd generation. There are several options in maximum torque available, also the gearbox is available with mild hybrid and plug in hybrid options: With 15 kW and 200 NM supporting boosting and recuperation in combination with 48 Volt technology up to 90 kw and 250 NM for usage with higher voltage. [11]
