Horn Fuse for Challenger ?
Welp, went for a ride today & almost got clobbered, went to lay on the horn & no joy :(
Anyone know which circuit/fuse controls the horn ? Everything else seems to be working correctly :unsure:
Nein. Versuchen Sie es mit Google
Interwebs were my friend - it's a relay (#41). Under the lid of the fuse block there is a detailed & labeled map of the fuses & relays.
Disturbingly O'Reillys, NAPA & Advance are all out of stock :( tho it looks like Auto Zone may have them.
FYI, relays do have a mechanical aspect to them and can sometimes be repaired after some disassembly.
Part seems to be $17 - $24, so hopefully I can just find a new one.
Also looks like there is a mini-fuse (#11) that has something to do with that circuit, so off to have a look at that too :rolleyes:
Good Luck,
I saw it was a 20 Amp
