Super Magnet Drain Plugs Dodge, Ford, Nissan, Toyota
Have Super Magnet Drain plugs available now for Dodge, Ford Mustang-F150 others, Nissan Rouge Murrano others, Toyota 4Runner-others. Others by request. All fitted with high strength high temp magnets.
Dodge any app that part numbers below fit, check your application.
Engine drain plug 6507741AA
Oil Cooler drain plug 68240988AA
Differential 68530769AA
A8 Transmission 68261581AA
M6 Transmission
EJ7Z-6730-B
Nissan Rouge - Murrano others
11128-01M1A
Toyota 4Runner - others
90341-12012
PM me if interested.
If your interested in something else get me a OEM part number of your plug and I’ll get one and fit the largest magnet I have into it.
My oil has been a bit glittery since whacking on the crank with a sledge hammer (thrust bearing maybe?) I may need to finally get one of these, but I just changed the oil for the best 2 years/200 miles
Could be thrust bearing. Why were you whacking on the Crank Shaft with a sledgehammer lol
You can change the drain plug without losing any oil just put a shop vac on the PCV port and draw vacuum on the crank case and air will bubble through the hole while you quickly take the standard drain plug out and put a magnetic plug-in.
With bread to get the pilot bearing out to put in pilot bushing. Didn’t work lol
Wow, bread trick worked every time for me, you have the bread too wet maybe or the clearance around your drift pin was too big? We talking a bushing for an A8 trans or a M6 bearing?
Taking out m6 bearing to put in A8 bushing. Had to modify a slide hammer attachment and it pulled right out. Threw bushing in freezer for a few hours and it slid right in. Bread was dry, maybe I should have tried wheat? Wonder bread? Potato?
I doubt I damaged thrust bearing. Crank gets all kind of pressure, wallops with a sledge and socket shouldn’t have phased it. It’s fine, I’ll do an oil analysis next change - I couldn’t find my kit when I was changing the oil. It looks fine
Fresh fresh white bread, no crust, just the centers. Yes, Wonder does wonders!!
Martin
2018 Dodge Challenger Hellcat
These things kick ass!
Trackhawk, RS3, Golf R
those are dope thanx for posting
Bowlerguy92
PM sent
