Ok ran some good logs to get what I think is the final test on the ID1000 injectors, dual pumps, and full E85.
Ambient temp was about 55 deg F, car made 17.5psi, aircharge 1800+ (good air), log read 86% alcohol. Inj DC never went over 82%, fuel pump DC 78%, and 80psi fuel pressure at 6500 RPM. In 30 degree air I might see another 5% give or take, so I'm approaching the limit of these injectors, but they're not at, or over, the limit so good news I can save a few bucks and not have to buy more injectors as long as I stay with just the 2.72 upper pulley.
So with this test the alcohol content has a lot more to do with the injector DC than the actual air or air temp from what I found. My testing had the following results on the ID1000s. The newer version of these is the 1050x and I think flow about 5% more fuel on top of what I'm getting on these 1000s so people with those will be in even better shape, especially if you're on a 2.85 pulley. You will definitely need the dual pumps though.
E57 - 70% DC and +3 deg timing over 93
E78 - 75% DC and +5 deg timing over 93
E86 - 82% DC and +5 deg timing over 93 (so far not sure if we'll add more or not)
