FS 20 mm Pass Thru Spacers
Motor Sport Tech Pass Thru Spacers.
4 Hub Centric 5 x 115 x 71.5.
Cost me 230 (shipped)
Sell for 130 (Shipped)
Typical application?
(Size wheel)
Custom built for the 2016 Challenger HC.
I imagine they should work on all vehicles with that hub diameter (5x115x71.5)
They were used with OEM, cheap aftermarket, and also Triumph 20 inch wheels.
I would think wheel size wouldn't be an issue.
Still for sale.
And still..
TrackDay
Great White North
2016 Dodge Challenger
What stud did you use with them?
ARP 1 inch longer than stock (could not locate 3/4 inch longer than stock). I am sure they are out there, I just could not find.
Scottsdale
2019 Charger Hellcat
Scottsdale
I only need 2 of them, but I would assume they will fit a 2019 Charger Hellcat?
How much?
How much?
They should.
You will need to replace stock lug bolts with 3/4 to 1 inch longer than stock.
I could not find 3/4 longer, but I am sure they are out there.
Let me look into shipping costs with 2 verses 4.
Then I will get back to you.
Scottsdale
They should.
Sounds great thanks!
There is a stud that is longer for an F250? by Dorman that you can use.
I will try to find the pn.
