- Macomb
- MI
- 2021 Charger Redeye
Hi Guys. I installed the JXB center bearing on my perfect driveshaft on a 21 Charger RE because I am adding horsepower for this season. Well, I got an instant vibration at 80-85 mph. The cause of the problem seems quite obvious....the driveshaft is now pushed WAY over to the drivers side. The mounting bracket is already solid against the passenger side of the driveshaft tunnel so it cannot be adjusted any further. And the mounting bracket does not allow for removal of that amount of material to get it right. So I ruined a perfectly good driveshaft for nothing and am installing a new one this weekend.
I have contacted JXB and am waiting for a reply. I did trip over a bunch of guys on another thread somewhere with the same issue, but the thread was not under JXB. So I started this one. Maybe if enough guys post that they have the same problem JXB will make a bracket for us that fits cars with this issue. I have to assume that for some reason our driveshaft tunnel is off a bit from the factory because most guys do not seem to have this problem.
1
