Occasional Tire Shake
Turns out TPMS sensor was intact, tire was literally shredded inside, manager of 25+ years at this large tire facility never saw anything like this before. Man am I lucky I didn’t have a blow out at 175+. Moral of this story, NEVER assume something as critical as a tire problem, it could cost you dearly.
New Nitto 555GII’s went on this weekend.
View attachment 16663 View attachment 16664 View attachment 16665 View attachment 16666 View attachment 16667 View attachment 16668
That is crazy the way it is coming apart , you are so lucky you didn't have a blow out , it wouldn't have been much longer.
Thread Starter #42
I guess when you do close to 200 often having 200 mph rated tires isn’t an option it’s a necessity!!
Don't forget that higher speeds (even on speed rated tires) require elevated pressures as well. Tirerack.com has an excellent document covering this.
Thread Starter #44
Thanks, but Fronts are always around 36 psi cold, wasn’t a tire pressure issue, not on my watch at least
#45
Ah, I see. Those are run flats. That extra body material must not have been balanced well or as noted manufacturing defect.
No doubt , at close to 200 , better have good brakes too.
Decay
Astoria
OR
2019 widebody Redeye
#47
Speaking of run flats, anybody ever run one flat??
#48
No.
Decay
Astoria
OR
#49
