Supercharger coolant drain?
Henderson
NV
2018 Trackhawk
Is there a drain location for the supercharger coolant? I think I have air in the system after installing FI spacers. Would like to pull a vacuum but the system has to be empty to start.
There is only a air bleeder device on the back of the SC, takes a 7mm socket if I remember correctly, no drain. Getting all the fluid out of the coolers is next to impossible on the car short of blowing them out with compressed air and that still probably wouldn’t get it all as their parallel fed and the air is going to take the path of least resistance and leave fluid in the DS cooler.
Tempe
2019 track hawk
There’s no drain only a bleeder valve
