My 2016 Hellcat build and update post.
Your wife steer the car or run the winch?
Nope. Not necessary. Once it’s lined up at the base of the ramp, it’s operated with a remote. Minor steering correction from along side as it goes in is the most that’s need. It’s a one man operation.
I don’t like it because then it makes the front uneven with the sides
Thread Starter #225
The Smurfs new heart!
Thread Starter #226
Thread Starter #228
Sounds like it has a miss how much oil is in it?
Hahaha 🤣 it actually took just over 8 quarts from bone dry to the full line. That’s drained oil cooler and fresh engine.
no misfires at all.
no misfires at all.
See too much oil in it drain about 2.25 qts
Hatermkr
West bend
2016 helldemon
Let it eat
Thing sounds like it’s running great, always good stuff out of demon performance. Did they build you short block, or did you piece it together?
Thread Starter #232
they did the short block and cam to what we decided on for my combo. I bought Thitek heads and did all the rest myself.
Thread Starter #233
I always am bemused by the "plastic" timing chain guides. I know they're designed to last the life of the engine and give an indication of problems if there is accelerated wear (and that they're not "plastic") but they still look to me like they'll be chewed to bits just a few minutes.
Nice looking motor. Bet it will be fun!
Looks and sounds GREAT!!
Who’s oil pump did you use?
Thread Starter #236
New factory Hellcat pump. More than enough PSI. 68 psi cruising hot, 50 psi hot idle. haven't gone WOT yet but I've seen 72psi at 4500rpm hot.
RACECAR!
Thread Starter #238
Are you a fancy fruit or vegetable???
Thread Starter #240
place has awesome breakfast sandwiches!!
