Let’s build a race car
Am I insane?
  • Total voters
    19
That looks bad ass, I'd leave it wide open just like that.
Thread Starter #423
coolant lines run. Ill make a full video in daylight.
rain sucks
Thread Starter #425
Holley stuff is in. Need to figure out a MAT sensor.
In this photo you can see the MAT sensor is right against the TPS, there is no way to get a sensor on there. I have an IAT sensor in the intake that could work but I'd rather not take the temp reading from there.
It's all downhill from here, switches, cage and then some tuning. Then a debut of sorts... I'm starting to get nervous as the momentum is building.
Thread Starter #426
Sitting here trying to finger fuck dodge connectors and I had enough of the bullshit on the harness. Snip, snip, snip. Crimp, crimp, crimp.
MMX harness adapted to Holley EFI on the MAT PIGTAIL.
For now I am making use of the stock map sensors. 😎
Thread Starter #427
What are the best options to fly in and out of Bowling Green, Kentucky. I will be attending the Holley EFI Tier 1/2/3 courses (the gauntlet) and will hopefully certified by the end of it. I'm in awe that there is no major airport. I see Nashville is south of Bowling Green should I just fly in there and get a rental and drive up? @Speedy! you are a resident of the region, thoughts?
Is the drive to far? It's kinda located in the middle of nowhere.
Thread Starter #429
73 miles north of Nashville
Don't know how accurate this is.
Thread Starter #431
Not accurate at all.
There's DC to Bowling Green flights.
Thread Starter #434
BNA is Nashville. Not Bowling Green.
Tricky fuckers. I kept getting switched. Not finding anything.
There might be a puddle jumper from the main airport to a small local one. I would call the course coordinator and ask. 73 miles isn’t a lot
Hope you get some good info there.
Airport in BG is small. Nashville would be your best bet unless you can save money flying into Louisville, KY. How far to drive for you? Somewhere around a 500 mile drive for me I have done many times
Trackhawk, RS3, Golf R
Wow ur not messing around that things dope!
Thread Starter #440
Good idea will do.
Me too, the other class I am taking by Joe Simpson he is interested in feedback from me about the class as well.
I think Nashville + rental car is it.
Thank you!
