Sign Up! To view all forums and unlock additional cool features
@Speedy!
Yes I did get the wiring question answered . I had to get a new connector from the dealer .
Thanks . I'm really happy with the out come .
I'm going to do a write up of how I relocated the power steering resiviour. I just want to test it on the road first .
Well folks the drive shaft is in and the exhaust is back on . I'm just waiting on the new windshield washer hose and nozzles and a new connector for the fuel pressure sensor . Then I will start planning my next round of "sneaky"
Nice goin, keep it up.
Now if I can only play shuffle the cars game. I might be able to get stuff done myself. But I guess there isn't a big hurry yet. No where to go.🤷♂️
Ok so I broke my connector for the fuel pressure sensor. It took the dealer awhile to locate a repair kit but here it is .
It even has preassembled wire leads in 2 different guages and shrink wrap .
And for those of you wondering how I got around the power steering resiviour here are a couple of pics from my mock up . I used the top return fitting and resiviour from a 6.1 car . I was quite surprised the see when I removed the resiviour from the hellcat pump to find the threaded hole for the retaining bolt just like the 6.1 pump . I did have to dig in to my O-ring kit to find an o-ring that fit properly . I mounted the resiviour right beside the brake resiviour so I can check the fluid easily . I also put a heat shield over the hose as I ran it with the A/C lines . @Speedy!
So I have a BT cap on my PS pump and it's REAL close to my coil pack cover. I've been looking if I can space it up 2-4mm. Do you happen to have a picture of the res off the car? I'm having a hard time seeing how it bolts up. Nice clean solution you did there. I'd paint the straps purple
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
