TIME SLIP CHASER ,SMACK TALKING ,THREAD HIJACKING,HP TUNER , HELLNO THATS ME
Thread Starter #141
I think speedy iz skeered that the DEVIL CAT will devour 6F1A505B-9895-4E3D-93AC-0D920BD594D9.jpeg his soul
Thread Starter #142
I asked him to come down last week but he said it was too hot mid to lower 70s YES SPEEDY IT VERY HOT HERE IN HELL. BAHAHA :devilish::devilish:
Thread Starter #143
Ive got tender viddles here speedy speedy here speedy speedy :ROFLMAO::LOL:
HarleyHetz
ARLINGTON
2019 Sublime Widebody Challenger Hellcat
I looked and it doesn’t look dirty but you can only see so much it still had over a half tank of gas in it and that race gas is blue so maybe to hard to say for sure but it could be coming from the passenger side because there’s a rubber hose that feeds fuel back on top of the pump which I believe is a siphon from the passenger side tank and the dealer had it apart two times because the secondary sending unit kept throwing a fault they fixed it once and it went about 600 miles and then they had to do it again and the second time they even said they put a new pump in as well they had it about two weeks both times
Use a cigarette lighter to help you see...:devilish:
Thread Starter #145
F::::k that I’ve git a torch
As you know here in hell we like it hot :LOL::ROFLMAO:
Now if o can only get SPEEDY to come to Memphis because my cat feeds on mangoes
LOL, I would like to see that myself , sounds like a call out on SPEEDY ! :eek::whistle:
Any idea what boost I will get with 10% overdrive ?? Added to my 2.85 litens
If or when I ever add more boost ? …. I think that's what I'm doing - ATI 10% lower , less labor than doing the s/c pulley. Just not sure if I should do Demon injectors or FIC 1000cc injectors ?
Thread Starter #148
What’s that I hear speedy ?????
Nothing but silence when DEVIL CAT is lurking in the shadows
Thread Starter #149
I actually found the super charger pulley to be quite easy
Thread Starter #150
Maybe I’ll change to a 1.0 upper pulley and spin the HELL out of it lol
Thread Starter #151
I believe it will be more difficult to do the overdrive pulley
yeah , I've had mine off once already for the spacers but would still have to remove the snout & get the tools to remove pulley. to do the lower just remove belly pan, both belts, rad. fan & your down to pulling the damper. Seems to be less work.
& have to remove the BOV to remove snout.
Thread Starter #153
When I do mine I’m going to pull the radiator and all that crap out of the way so it’s easy to get to
When I pinned my crank I only removed the rad. fan out the bottom & with a 90* angle drill I had no problem , so I'm thinking the dampener removal will be the same ?
Thread Starter #155
Mines not pinned it’s runs on faith
Then throw the ATI hub in the oven for a while & some anti seize & slide it on.
Thread Starter #157
Can I do that
I thought that in hell - there is no faith :devilish::ROFLMAO:
yeah - just the steel hub , I did it when I did a ATI on my 15 GT Procharged.
Thread Starter #160
Even in hell we have faith lol
